I just bought a used 2012 Little Phatty Stage II (LPT006). It seemed like it was a little out of tune, so I performed a calibration. I warmed it up for like an hour, did a full note calibration, then the PW amount, which both finished successfully. Whenever I run the Osc2 Freq calibration my Little Phatty freezes up. The only way I can use the instrument again is to do a factory reset.
http://forum.moogmusic.com/viewtopic.php?f=7&t=21319&p=129569&hilit=calibration+freeze#p129569
I found the above previous post where someone else was having the exact same problem I am having, and he mentioned that the unit had a bad ground that was corrected, which ultimately fixed his synth. I have a lot of experience in electronics, is there a fix that I might be able to try myself? Has anyone else had this problem and successfully resolved it?
