Is it possible to run the LFO ( native on the Voyager, or with an external unit of some sort ) so that you have control over the upper and lower limits of the LFO sweep?
ie: right now the LFO runs in a cycle through it’s full frequency range, and the only control you have is the speed
but if there were 2 other parameters you could adjust…being able to set the upper limit and lower limit of it’s range, I think that would be incredibly useful
example: when using the LFO to drive the cutoff filter amount, you could set it to only run
- the top portion of the sine wave
- or only the bottom
- or any range of defined upper/lower limit
a dedicated lower limit knob & upper limit knob would be great
Does anyone make anything like this, and could it be hooked up to the Voyager?
thanks!
