Hello and thank you to anybody who can help. I cannot access the LCD contrast control on my Voyager. The manual says to go to “Master” upon booting up the machine and it is the default option. Not on mine. There is nowhere on my machine to adjust the LCD. My unit is an early unit (version 3.5 software). Any ideas?
Hi, I don’t own a Voyager, so this comes only from the manuals and an old thread here. Please treat it as a lead, not a sure answer.
The original Voyager manual lists LCD CONTRAST as the first option in MASTER mode, and the setting is changed with the -1/+1 buttons. The later Voyager XL manual puts the same setting under PANEL mode instead, so on an older software version like 3.5 it could be in either place.
An old thread on this forum from 2008 suggested two things to try: MASTER, then Enter, then press -1 repeatedly; and if that does nothing, PANEL, PANEL again, Enter, then -1. I can’t confirm either for 3.5 specifically. If neither shows a change, Moog support could tell you for your unit.
Hello Rei-
The second instruction (panel panel enter) took me to a hidden screen that has the LCD contrast adjustment. THANK YOU. Even the guys at Moog didn’t know about that (?). I can now adjust my display. It doesn’t seem to save the change after I power it off, but at least I can adjust it. Thanks again- Matthew
You’re welcome, Matthew, glad that screen turned up. I haven’t verified why the contrast setting doesn’t stay after power off, so I can’t say if that’s expected on 3.5. Does it come back after a restart if you leave through the menu’s save or exit option instead of just switching it off? Worth knowing if so.
