Latency midi cc automation problem
hello,
I use my moog voyager with ableton live. When i play a midi track to control my moog in ableton. All notes are well played but when i draw an envellope of midi cc n°19 (wich is the moog’s cut off) it’s sounds weard :
the loop never sound the same !
in preference of ableton live i have 10ms of general latency.
why cut off or other automation doesn’t play correctly??
Thanks (and excuse me for my bad english language… )
same here for me and my Moog Voyager!!!
AND I bought the Moog Plugin (soundtower) and installed the newest version of it.
No chance to automate my Voyager :frowning:
That’s really bad because I need some really accurate automation of LFO times to my song, which can’t be done manually.
PLEASE HELP!
my system is: MacOS X.6.8 and Live9suite, Moog Voyager is MIDI wired through an Unitor Mk2, MIDI connections at LIVE prefs are off (In/Out) - everything is controlled by the plugin (which is working fine while NOT automate anything!), same disfunction is without the plugin (LIVE prefs MIDI is ON!).
