Korg SQ-1 a sa memory for MoogerFoogers and other analogue effects
Here’s a tip I’m sure I did not invent, but I feel it can be useful to some of you.
The Korg SQ-1 can memorize 16 CV values and send them through 2 outputs. Provided your FX pedal has an expression/CV input, you can use the SQ-1 as a CV memory unit.
Set it in Active Step mode to activate only one step and start the sequencer. Connect the apropriate CV out to your FX pedal CV/expression input and adjust the step pot to taste. You may want to adjust the range of the pot (1 to 8 V/Oct).
Repeat for as many values as you want to call back. When you want to change the preset value, just switch on the right step.
Alternative: in Step Jump mode, you don’t have to run the sequencer but each step is then triggered by pressing the step button. Consequently, you can here the change value effect only by pressing that button again.
Of course, this applies to any CV sequencer, but provided the price tag and footprint of this one, I feel it does the job brillantly. Plus as it can function as two sequencers with each its output, you can use this trick for two pedals simultaneously.
never really thought of that one, got to try this out! Thank you!!
hey that is a pretty neat idea! thanks!
Hi everyone,
I actually used something like this years ago in live performance- a (primitive) Technosaurus Cyclodon sequencer (16 steps, just one cv and gate) to provide a single cv to go to an MF cv in (eg cutoff freq or resonance on MF101). It works, as one would expect. I don’t own the Korg sequencer mentioned, but having multiple layers of cvs of course makes the idea more flexible.
If you’ll allow me a departure from Moog-branded instruments, a newer box which works fantastically with this idea is the MakeNoise 0ctrl. 8 steps, running as sequence or selected by individual touchpads. There are 3 layers of cvs, each of which has a ‘designated’ purpose within the MakeNoise world, but which are all available via sockets as well. So 3 parameters controlled simultaneously on 1 or more MFs. And the touchpads are pressure-sensitive, with another cv out. So you can use the box to set up an MF with cvs and then ‘play’ an extra parameter via pressure.
I admit that I haven’t used this setup with my MFs, but I have used it with my Macbeth MicroMac D (synthesizer, expanded MiniMoog architecture with extra cv connectivity). Works like a dream.
(You can check it on my soon-to-be-released CD - ‘Songs from the Lake’, NEOS Music 12029, https://neos-music.com/ under ‘coming soon’. Particularly used on track 4, ‘Mirrored Depths’.)
JimF
Thanks for sharing, JimF :slight_smile:
Indeed, I saw a couple of vids about that 0ctrl and it seems very handy and well thought. I’m not a huge fan of sequencers as they tend to “freeze” the music a bit too much for me; so -to me- sequencers allowing for real time playing while running certainly are an interesting option.
Pretty cool stiiiiive. I use a couple of Behringer 960 clones, with 962’s. They’re super inexpensive, and once you replace the potentiometers, pretty accurate to boot. They’re fun to use with DFAM and SunH too.
Now to eurorack my moogerfoogers someday…
