Anyone else find the clicky attack a bit strange? On youtube demos it seems to be there as well.
I love the sounds but it’s going to be hard to actually use them in a mix with that attack noise
This has been frustrating me as well. If anyone has any suggestions, they would be greatly appreciated.
If you have eurorack, you could slow the attack of EG1 and EG2 by means of a Behringer “Abacus” or Makenoise “Maths” module, which are functionally equivalent.
Connect EG1 out of Labyrinth to IN1 of Abacus/Maths. For Abacus channel 1, set Level to maximum, Rise to around 12 o’clock, Fall to zero and Respons curve to LOG. Then connect OUT1 to Labyrinth CUTOFF or/and FOLD, depending of which effect you want to slow down. Try different settings of Rise time and Level in Abacus/Math until you have get the desired effect.
Additonally or alternatively you can proceed likewise with EG2 → Channel 4 → VCF/VCW VCA CV to slow the VCA attack time(s).
That should do the job.
