Hey. I just bought an MF Drive, too, but I’m having some trouble.
Bought the first one, brought it to the rehearsal space, put it in the chain. Wow. Looks lovely, sounds beautiful. I have a number of different gains on my board, and it stacks with them beautifully.
Then, it hits the fan. Starts cutting out intermittently.
I’m powering it with a one-spot, so I take that out and use a dedicated power supply. Still problematic. Change out the cables. Still problematic. I lean it against my board at an approx. 45 degree angle and it’s better…for a while. Then it cuts out again. I take it out of the chain and run it by itself. Still problematic.
Sigh. Well, it’s early in the run, stuff like this is bound to happen, I think. Take it back to the store and exchange it for another one.
Lather. Rinse. Repeat. Same issues. Exactly the same, down to the improvement when leaning it against the board as opposed to it sitting flat.
Now, my thought is that, because it’s happening the same way with two different MF Drives, that the problem is on my end. But I thought I did a pretty good job of troubleshooting (different power supplies, different cables, out of the chain, etc.). What am I missing?
I really like it and want it to work out, but I’m not sure what’s going on. The only thing I can think of is…I saw there is a battery in the pedal already, and I think it’s dying, because when plugged in without a power supply, the bypass tone comes through but, once engaged, it doesn’t light up and there’s no signal. But I didn’t have time to take it out and test it without it. But would that be the problem for both?
Any suggestions/thoughts are most appreciated. Thanks for reading.
