I have a Eurorack modular system and a DFAM.
- I would like to have my Eurorack modular system control my DFAM. In particular, I’d like to be able to play through the sequence on the DFAM using the modular as the controller.
Is the correct way to do this to patch a gate from the modular into the ADV/CLK patch point on the DFAM? This only seems to work if I also press the red PLAY button on the DFAM. Is this correct?
- I suppose the other way to integrate the DFAM with the modular would be to simply make use of the patch points on the DFAM and use a sequencer on the modular to control the CVs going into the DFAM. Does anyone know what the CV voltage range that the DFAM accepts, and what the range is that the DFAM outputs? Are they all Eurorack compatible values (-5 to +5V, or 0-10V?)
Thanks for any info!
