Insert I/O
Hi
Is there any harm done if I connect my Moogerfoogers (Delay,FregBox,Processor and Ring Modulator) to my mixer via the insert I/O?
Simon
Hi.
Welcome to the forum. (noticed it is your first post.)
Some info here:
http://www.moogmusic.com/forum/viewtopic.php?p=26534&highlight=#26534
I put effects, including everything you listed in the loop all the time.
Go ahead… experiment!!!
Welcome, Simon!
If I understand your post correctly, you’re talking about an insert point in your mixer, not the insert point on the Voyager. The forum link that analoghaze suggested is for information on using the Voyager’s Mix/Out insert loop (if you do have a Voyager, I definately recommend that you take a look here - lot’s of good info - otherwise you can probably disregard it).
The answer to your question is that it should be fine to use the Moogerfoogers in this configuration without any harm. Moogfoogers are designed to handle a wide range of inputs and can easily handle the line-level signal of your mixer insert. Note also that you could also connect the 'Foogers to an Aux Send output for use as a global effect on all mixer channels instead of just a single channel-based insert.
Have fun!
:sunglasses:
sorry, I read that wrong.
:blush:
Hi
Thanks for your help.
Best
Simon
