Here are some .zip files containing individually-saved presets from all three Little Phatty factory preset banks. Thanks very much to Francisco Demichelis for exporting the Tribute and Stage banks.
edit-to the above post,i believe you can use the tribute patches on the phatty se/2 im not sure about the TE ,i cant see why not though,from memory non of the lp se/2 patches use the added extras in the os(arp etc).
im 90% sure you need a upgrade to the TE memory if you want the os 2.1.
hey guys!
i use the SEII and TE in my SE, and have no problem
i really did a very good compilation mixing the 3 banks
i don’t know what happen if you use the others in the TE
maybe nothing, i dont know
i am happy because seems like you’re enjoying what i did
thanks for your words
cheers!
I am not 100% sure what will happen if you load SEII patches into an original Tribute Edition… at worst, the preset won’t work or will not load.
There is no harm in trying it. If your LPTE has OS 2 then the presets will definitely load. If the TE has an older OS then it might not know how to interpret the newer preset format.
Best-case scenario, it will work and the only difference in sound will be if the mod wheel is up; any SEII presets which use “mod destination 2” will not have this mod destination active on the TE. So there would be some (slight to extreme) difference in the modulated sound, but no difference in the unmodulated sound.
