Hi all,
This problem, my Voyager has had since the beginning, but I always thought I should just live with it. But in reading some posts, it seems this might be fixable.
Say I have Osc 1 and 3 on. They’re both in the same octave, have the same waveform and volume, and are in tune. Identical basically. Now when I throw the 3KB Cont switch to OFF, Osc 3 is supposed to become a drone. On mine, it also drops an octave, whch I think is normal.
What is not normal, is that it goes slightly sharp. But I can’t just lower Osc. 3, b/c it sort of jumps and interval. So I have to go below the pitch, then tune up.
What this amounts to, is that I can’t use 3KB CONT on the fly, performing live, etc. Or if I do, I have to quickly retune it.
The other problem is that if I turn 3KB CONT to “On” (non-drone mode), it’s now out of tune, and I again have to quickly retune.
Perhaps the problem stems from the fact that, for Osc 3 to be in tune with Osc 1, Osc three has to be at nearly +1. This has always been this way. In fact, I believe someone told me this was just something I was going to have to live with. Not really changeable.
Any help on this topic would be greatly appreciated.
The irony is that I once sent it into NC, with S. Dunnington’s assistance, to deal with another problem, which turned out to be just a matter of tweaking, not a hardware repair. I believe he said they did a re-tuning at that time. I’d hate to have to send her back in…
Finally, a side note. I’ve been drooling over the MF-104Z, if anybody out there is using it with the Voyager, let me know what you think!
Thanks in advance!
-brian
