I have the pitch control out of my VX 351 going in to the keyboard control of my Moog Rogue. When it’s plugged in, a very high frequency is emitted, much like a dog whistle. All instruments play fine, but this frequency is constant. Is this inevitable with this setup, or is there something I can do to fix this?
I thought of that initially, but I also have a stereo insert plug (where there’s a stereo plug that separates the ring and the tip into two separate plugs.) and it still does the same thing, so i’m at a loss.
Chris - do you by chance have your CP-251 powered daisy-chain style from your VX-351?
If so, that’s the source of the problem. Sometimes a “ringing” happens between the power circuits of these two devices. The solution is simple enough; just power the CP-251 from an external (wall wart) adaptor instead of powering it through the Voyager. That should eliminate the sound.
