How to sync the Moog-Mother 32 to Logic Pro X ???
Hello everyone,
Could someone please please explain to me (step-by-step) how I could sync the Moog Mother to Logic Pro X?
I’ve got:
Focusrite Scarlett 2i2
Novation Launchkey 25
Logic Pro X 10.10.4
Make sure you have the Moog32 set to midi sync in the set-up menu. In Logic, go to Project Settings. Choose Midi. Under Midi, choose transmit to Focusrite, then choose Mode, Pattern,
Then below choose Midi Time Set Transmit MTC, All, Then below choose Midi Machine Control (MMC), and choose Transmit and Listen. And then you are good to go. Good luck.
I know the software is different, but this might help you or give you some ideas on how to sync it up https://www.youtube.com/watch?v=7M83loWucNc
This is through Ableton, but Logic may have similar options to achieve the same effect.
