I just got my etherwave plus and slim phatty. Neat neat neat devices, and my first analog synths.
I’m thinking of some wild things to do using the CV output of the theremin… like controlling lighting and visuals… but information seems scarce on converting CV to MIDI values. Can anyone recommend a solution? Does Moog produce one?
Have you looked into pd or Max/MSP? both of those programs are modular DSP/MIDI programming environments that have objects for measuring pitch and amplitude.
Because the theremin is a monophonic audio signal w/ a simple waveform, it’s really easy to extract MIDI data directly from the audio.
I’m looking into this too. I want to have Etherwave Plus CV converted to MIDI Continuous Controllers for lighting, effects, VJ apps- all possibilities for the best gestural control of all time.
I’ve done the Max/MSP patch a long time ago with a standard Etherwave. This requires audio in- not the CV available with Etherwave Plus You need an object called Fiddle for pitch detection. It warks great for standard controller applications but generating meaningful MIDI note on/off data is more complicated.
I’m interested in a hardware only solution wthout a computer. So, using Etherwave Pro CV outputs would require a CV to MIDI converter. These are much less common than MIDI to CV converters. Most contemporary CV to MIDI converters are in a Eurorack modular format. Analog Solutions, Analog Systems and Doepfer all make some variation. Analog Solutions and Doepfer are only designed for +5 volts. The Etherwave Plus can output as much as +10 volts and also generate a negative voltage. Analog Systems RS 300 looks to be by far the most comprehensive and can be set up for a wide range of voltages.
Another solution is to use the Expression Pedal input on a synth or MIDI controller. It gets complicated because most of these pedal inputs are designed for a TRS cable with the synth providing the power for the pedal. Because of this, I believe, not all expression pedal inputs are going to be happy with CV on a standard TS cable. It is also rare to see two chanels of expression pedal inputs on one controller. Supposedly the Voyager Mod1 and Mod2 inputs will output MIDI and they are apparently safe beyond +5 volts. Another possible candidate is the old Peavey 1600x MIDI controller with 2 pedal inputs- the manual states that they will handle +10 volts. I’m currently sniffing out the two pedal inputs on my DSI Tempest but I am nervous about plugging in!
Third solution are MIDI “brain” boards by Doepfer and PAiA. These are strictly for +5 volts and seemingly would require voltage attenuation if used with Etherwave Plus
I’ll post more as I found out what I’ve been able to do.
Dont know whether this would be suitable but to dispense with a computer entirely you could look in to Analogue Systems CV to Midi converter.. its made for eurorack so youd need a mini case.. you can do funky things with CVs with this box.. I have a large Analogue Systems Modular, but this is one of the few modules of theres I dont have.. get the pdf from their site and see if its suitable..
I´ll get my first theremin this month. I´m really excited and looking forward to it.
Interested here also for the same reason. Want to control lights and projection, through isadora/troikatronix software. If you dont know it, its a cool software for interactive stuff, inspired by analog synthesizers: www.troikatronix.com
So i need cv to midi or cv to osc.
I found this:http://www.expert-sleepers.co.uk/silentway.html
Do I need a hardware then?
I have the sonuus app on the iPad and it doesnt work for me (on the violin),…maybe it will work better with the theremin.
So keep me updated, if you find some good solution.
Although its primary function is to be a portable USB keyboard with
polyphonic aftertouch, per-key tilt sensitivity, and per-key PitchBend,
it also has MIDI In/Out and multiple CV In/Out, which can be used as
a converter in either direction.
This is one of the first thing I did when I got my Etherwave Plus a few years back.
Albeit expensive (there’s always e-bay), the Roland FC-300 foot controller will do that for you … times 3, that means it will midify both your volume and pitch cv from the Etherwave and leave you with an extra cv-to-midi channel. Simple TS patch cables work fine.
You can program any CC suported by the FC-300. You can set “heel” and “toe” (min and max) value from 0 to 127 (no 14 bits midi here).
It probably processes only 5 volts worth of the Etherwave voltage range, but I never had a problem with that.
In fact… cv-to-midi was the main reason I purchased the FC-300 (brand new for $200) and it has proved invaluable over the years.
Well the Roland PK-6 will do that… 1 channel only and it’s $900 (cough, cough), but it does other things too I do have a PK-6 but I never used it in that fashion.
Now seriously, there is another midi foot controller that will do it (2 channels). It’s the Behringer FC-2020 (I think). I came this close to snatch one on kijiji for $75 but someone was quicker than me. At $149 brand new, it seems to me like a very good option.
I love Behringer controllers. I most often use the FC-300 plugged into the Midi-In of a Behringer BCR-2000. It does not change the functionality of the FC-300 but it is nice to see the little LED ring show the midi activity and values being sent. It also adds functionality to the midi line at the tip of a finger.
Most midi controllers with an expression pedal input should also work. There probably are a number of them out there.
At what point exactly do you want your Theremini to output a Note-on or Note-off message? That is the trickiest point to define, as the typical use is to fade notes in or out with the amplitude antennae. Perhaps a trigger could be generated at an exact distance from the antennae? You’d also need a switch on the Theremini to activate/deactivate the Note-on/off function.
It seems like you’ve put some serious thought into this already. Curious as to how you’d see it implemented.
