If I have a clock signal coming from the 5 pin AND a clock signal coming from the analog connector, which one will have priority (if that’s how it works)?
The manual seems to imply analog will override either DIN or USB, but it really doesn’t say; the word order is correct if the above is the case, but it’s also possible to word it the way the manual does even if they DON’T mean to imply analog takes precedent. It’s not definitively stated.
I tried looking for a setting, too, but all I saw was switching MIDI on and off across the board per input/output type, which is not what this inquiry is about.
If anyone has tested this, can test this, has found is an official answer somewhere, does anyone know? Thank you!
