Hold button malfunctions when plugged in via midi
When I have my Messenger plugging into my Digitakt, there is some sort of malfunction with the hold.
If I hold a note (meaning, press HOLD button, hit a key, let it drone), when I turn the hold key off, it still holds. If I hit another key, it will play that note, but go back to the original note when I release.
Just updated software, still happens.
I have, btw, turned MIDI merge off (because of other MIDI problems I had trying to use Messenger with Digitakt
Take a look here for some further assistance: Messenger :
I clicked on the link you sent, which sent me to a page that has these topics, none of which seem to mention the hold button. Wrong link? Am I missing something?
Moog Messenger | Restoring Factory
Moog Messenger | Restoring Global Settings
Moog Messenger | Firmware Update
Moog Messenger | Tuning Procedure
Moog Messenger | Duophonic Mode & Mod Wheel Modulation
Moog Messenger | Hidden Modulation Assignments
Moog Messenger | Glide Configuration
These were only topics that I could see.
bump
here are twenty characters
