Grandmother gets notes stuck after using hold function
Hi everyone,
It seems after using the hold function the notes seem to be stuck on hold even though the hold button isn’t pressed anymore. I then need to press and depress hold one more time to reset it.
Any ideas? I have reinstalled the latest firmware already and no luck.
I have shared a video on reddit here https://www.reddit.com/r/moog/comments/xnzos7/stuck_notes_on_grandmother_after_using_the_hold/?utm_source=share&utm_medium=ios_app&utm_name=iossmf
Hello,
I have a similar issue. The led of the hold button is not lit anymore after pressing, but the sound just continues. Using firmware v1.1.3. VCA mode → ENV
I have reset global setting.
I can jam for hours with no problems but then it just appears. Very strange
edit; dubble post
It sounds like there might be a small glitch with how the hold function is resetting after it’s been used. Sometimes features like this don’t fully release until the button is toggled again, which can definitely interrupt the workflow, especially if you’re trying to play or record smoothly.
