Blackout posted this over at Gearslutz also; it is very difficult not to resort to an ad hominem response, because he is asking for it. As mentioned, most people have the Minimoog power supply plugged into a power strip, so it will most likely never be a problem. Sheesh…
One boisterous voice does not represent the multitudes… if he cannot accept the testimony of people more experienced than him, even from a certified Moog service center, then no amount of explanation will be good enough for him and he cannot be reasoned with. I get tired of talking to brick walls.
just because i posted something on Gearslutz does not mean im a crazy nut (like some) that post on there. Im over 40, have a wife and 2 kids, and run 2 recording studios. Youve never posted on Gearslutz ever? Your argument seems to be “Blackout is a crazy nut, hes posted on Gearslutz before…THERE …that proves it. So ignore him suggesting that you buy a backup PS because you dont need it.”
i dont believe that the Moog external line lump PS is going to last working 30 years non stop without failing. But you seem to think i am being “unreasonable” because of this? sheesh.
Feel free to believe that the PS will last! Some people will not take a helpful warning based on years of experience. You cant save everyone. All this post is…is a helpful warning and heads up to be aware of the situation. I think that is a very reasonable reason to post..to help others.
I’ve found dust covers online but all of them seem to require you to fold the control panel back down flat. I don’t want to do that every time I want to cover it up. I did have one made from a custom cover shop online but I just SWAGED it and gave them some numbers. The material ended up being a little thinner so it doesn’t work out quite like I thought. In fact it works better if I turn it around and use it. It would be nice to have one that was the right shape but this one works for now.
I own four original Model ‘D’'s, service them and they all stay in tune well enough to use live.
In fact, I have used my first Minimoog live since buying it in 1982 - it’s only ever let me down once with an open circuit glide control - no big deal, wear & tear and easy to replace.
Maybe you encountered old ones in need servicing or with faults..?
Regarding the external PSU - I don’t know if this is the case because I’ve never seen one, but if they’re one of those mini SMPS which sense and can be used on any supply voltage, then I would suspect they will indeed start getting issues down the line - simply because all SMPS power supplies will..! The old model ‘D’ internal linear PSU will run forever - needing maybe a recap or two along the way.
LOL. As much crap as the guy got who started this thread it has actually been a good thing. I was leaving my external power supply hooked up all day and all night…
Right , it is a plain meanwell psu with xlr plug . by the way the original plug was worn quite quickly , mini startet to make nasty things . my tech installed a neutrik plug which solves my psu problems .
I’m not familiar with the Minimoog reissue, but my Moog Liberation used an XLR plug from a remote power supply. One mistake was using the shell as ground because that connection isn’t entirely reliable. Not sure if the Minimoog reissue uses the XLR shell as ground.
