Firmware update OS 1.03 to 3.21
Hi!
I just bought a second hand MOOG Little phatty Stage I with the OS 1.03. Could anybody explane me please what is exactly the upgrade procedure?
I know that I have to do several upgrades step by step. I would like to update it to the ultimate software 3.21. I know that my OS is really old, but I need the arpeggiator function for my Little Phatty.
Thank you!
Hi, I could not do the same procedure from the same reasons! There is a risk of crashing the entire system. Now I’m looking for the firmware to restore the firmware via jtag. All the hope for Amos!)
The arpegiator was introduced in OS2.0. There is document titled LPOS20_Addendum.pdf -not sure it is still available online but I can provide it if needed.
This document’s Appendix A explains the update procedure. That will never been said enough: first save all your presets, then go slowly, step by step through the procedure. Some information about updating a Stage 1 LP in this topic.
For going to version 3.XX, there is a document titled LP_v2-v3_Update_Instructions_OSX.rtf. This one may be available online. It requires a supllementary step (loading a new boot loader).
Thank you very much!
But I can’t find the 2.0 firmware update?
Does anybody know were could I find it?
There is a 2.21 there, not sure if you should install the 2.0 first :confused:
I also have doubt about it…
Does anybody have the v2.0 OS ? :smiley:
The problem has been solved!!!
Ah! How? :slight_smile:
At first I updated my LP from 1.03 to 2.21 without any problem .
And then , I followed the instructions to updated it from v.2.xto 3.x. First I had to install the BOOTLOADER to LP and then after restart the instrument (or without restart, I do not remember) the bootloader has installed the last OS;)
Great, you are up to date now :slight_smile:
Hi Everybody
My second hand Little Phatty Tribute edition is running the os 1.03 and I would also like to update it to the latest. Could somebody explain me the whole procedure step by step? Which steps do i need to follow so that the whole instrument doesn’t crash? :open_mouth: Your help would be much appreciated!
Hi!
I think you should to write to Adam Pryor directly:
adam@moogmusic.com
I think he would answer you in a few days.
Hi
I`ll write to him, thanks!
Thanks for the contact.
IIRC the latest Tribute OS is 1.04. Anyone, correct me.
At this page you can see that the latest OS is 3.21.
https://www.moogmusic.com/downloads?category=All&product=203
But I think you should to contact with the Moog support first, and then READ VERY CAREFULLY the instructions in the document that goes with the OS update.
For stage version, indeed, but I’m not sure Tribute versions are numbered the same…
You can see it “v3.2.1 Firmware for Little Phatty Tribute Edition” at the same page :smiley:
I feel stupid: I’ve been looking for it and now I can see it in one second :smiley:
Sorry!
Okay, could somebody explain what this means: If your LPTE is still on OS v1, then you cannot update the firmware before first upgrading the hardware. So how do i update the hardware!?
