Filter CV trigger
Hell all,
I should be more sophisticated when it comes to the Moog but I’m not. I spent most of my time as a teenager listening to Switched On Bach playing and experimenting with a beat up Mini Moog and Realistic ML-1… So I apologize in advance. I am missing having a Trigger that will manipulate the Filter and LFO. If that makes any sense. Ideally I’d like to beat-match the Filter when I’m using Ableton. Maybe I need a MoogerFooger I don’t know. I was wondering if anyone here has a Youtube or Vimeo video demonstrating CV in.
Thanks,
Conrad
What do you mean “beat match the filter”? The filter has a dedicated envelope generator that activates on a midi note on message (or a high gate signal on the gate input jack)… If you are referring to the LFO syncing to a midi clock source, you can do that also. There are menu options in there about the LFO sync. Make sure its set to MIDI, and make sure Ableton is sending midi clock (sync) to the phatty. The LFO should sync to the midi clock signals (which you can route to the filter if you want)…
How is your phatty connected to Ableton? Are you using other CV gear?
Cheers.
