External keyboard triggering Voyager RME - Help
I’m running into problems triggering notes quickly on the RME with an external keyboard. I’ve tried a couple 'boards to control the RME, and get the same (lack of) results. I have to be very careful about releasing one key before I press another. Otherwise, the original note just gets cut off. This is bad, because I like to play fast like I can on the AE keyboard. I can’t just sloppily slur one note into the next like I’m able to do on the Voyager keyboard version.
I’ve tried different trigger modes on both the RME and the controller 'boards, to no avail. I haven’t run across this problem with any o my other gear.
Any help would be greatly appreciated.
jk
Well, thanks to the helpful folks at Moog Music, I found the answer. simple, and obvious, once you know it. The RME came to me with Master mode ‘MIDI Key Order’ set to ‘1st Key is active !’. When I down-arrowed to ‘is not active !’ the RME tracks my keyboards beautifully as a single monophonic synth. The selections for ‘1st Key is active !’ through ‘16th Key is active !’ let you stack up to 16 (!) Voyagers for one monster polyphonic analog system.
Thanks Tony and Amos!
