I’m a new owner of a Little Phatty Stage II which I’m enjoying very much.
I’m having a small issue with the ''EGR Reset" option though, it doesn’t seem to reset the amp envelope for every note as it should.
It seems to work most of the time, but one out of every few notes will ignore the attack portion of the envelope and skip straight to decay or sustain.
This is especially noticable if you set the attack high up, for a slow attack, and transition between notes while the envelope is still going through the attack of whatever note you played before - the envelope won’t always restart, and you’ll hear the envelope continuing just like in legato mode.
Can anyone else confirm this problem?
Thanks,
Gil
