I haven’t yet uploaded OS 1.3. I’m very curious about this EGR Matrix On/Off function. If you turn it off, does that mean you can’t access any of the EG settings by simply pressing the appropriate button and turning the knob? Do you have to go through the laborious process of pot mapping each time you want to change an EG paramter? I’m hoping that turning it off simply means that the knob transmits only midi data and not analog data, but you can still access any of the EG funtions with just the press of a button.
If the EGR-Matrix is set off, you cannot change the destination of the knob in the EGR section by pressing a button.
The knob itself works on the previous selected destination.
greetings
Volker
Thanks for the info. I guess you’d better have your EGs all set to go or be connected to a midi controller before you turn it off.
