Decay on/ off: Deference between T1 and T3.
I noticed functional difference of Decay on/ off between T1 and T3.
T1 stops sustain immediately once Decay button is turned off.
However, T3 does not stop the sound until a pedal is pressed after that.
For instance, if we play introduction of Watcher of the Skies with T3, we need special techinque to stop the last note, high C. :unamused:
This is no longer the case with the latest firmware revision. The decay (and octave) footswitch now functions like the Taurus-1’s, all of the tuning and arpeggiator issues have been resolved, and most importantly, the original “Taurus” patch now sounds the way it should (as do all of the T-3’s patches). If you haven’t tried updating your firmware yet, its very easy - all you need is a computer & a USB cable. :wink:
