CV Out?
Do you think Moog will offer a CV Out upgrade to the T3? Seeing as everything Moog makes incorporates control voltage i/o, it would seem logical, and it would use the same panel as the mod for the LP. I think that because the T3 is a limited run and is marketed to a very small demographic, most owners would want to go all out with their purchase. Maybe we could start a poll.
This was discussed early on. Pitch Out would be a no go for sure because of the V/Hz architecture.
Im down with that, Im even down with getting a breakout box for Hz/V -V/O conversion.
I think all we really have at this point is MIDI.
I had initially requested that the unit have CV Inputs, because I wanted to control the Taurus externally. I didn’t forsee myself wanting the T3 to control something else except maybe via the arpeggiator.
If you think about it, theres really not too much it could externalize except for pitch/gate/velocity that has a control on the front panel.
Unless Moog made a breakout box vx351 style designed to plug into the MIDI out, we might be sol.
