Crooked Screen
Hi Andy!
Switched on my brand new Moog 37 and noticed it has a crooked screen, can you please help? :unamused:
Everything else seems to be working fine… :sunglasses:
Thanks,
NK
:smiley:
bump bump…
Anyone ?
I had one that was tilted slightly to the right. The frame that holds the display module had a bit of wiggle room, and it settled in that position. I fixed it by wrapping very thin insulated wire around one of the mounting posts for the frame to reduce the wiggle room in that direction. As it happens, I have made some instructions and drawings for another owner with the same issue - I can send it to you if you want to attempt the fix yourself.
Hi
I have a similar problem with my new Sub 37.
Could someone please let me know what screws need to be removed in order to gain access to the back of the control panel?
I don’t want to remove more than is necessary.
I’ve attached the aforementioned instructions. It’s a ZIP archive with a PDF file in it.
Please only attempt this if your Sub 37 is out of warranty, or if you feel confident and competent enough to do it. It’s not hard though…
LCD_fix.ZIP (93.5 KB)
@DrJustice
Thanks very much for the information.
Much appreciated
How many screws need to be removed to get to the LCD?
@DrJustice
Apologies. I see that you have described how to remove screws etc in your instructions.
thanks
