For those of you with a cp and little phatty, I was wondering if it was possible to create auto s&h the older moogs had by pluging the square wave from cp into the phattys gate in and then the cps s&h into the pitch or filter in on the phatty. So basically the square wave is triggering the note on and off and s&h is changing the pitch/filter cutoff.
Thanks for your input
Yes, I just tried it and the patch works well, both for cutoff and for pitch. Also, it sounds good using either the regular s&h output or the smoothed one.
Exelent! That was one thing I missed from the new moog gear. Good to know with a little patch work its still possible
