CP-251 vs. Multipedal vs. Voyager LFO
Third post on the same subject but I wanted to reach as many as possible.
Looking to avoid the purchase of CP-251 and instead get a Multipedal and VX-351. Here’s the background/questions: Thanks.
– – – also posted on Voyager and Controller forums – – –
I know many of you have these, so I have a few questions. I was going to buy a CP-251 but just can’t resist the Multipedal at this price. So here goes.
The 351 and 251 have a few things in common, namely:
  • 2 Attenuators
  • 2 four-way multiples
And square, triangle, noise, and S&H generators. Granted, the 351 gets it from the Voyager so to a certain extent, you can’t use these if you are using them for a patch (or can you? That’s question #1).
The 251 has the LAG processor and a Mixer and the 351 doesn’t.
So I’m getting the Pedal and I understand that it has LFOs and Midi so I’m going to be using it as my clock source for many things. I also have a Phatty with CV outs so have the Mod bus at my disposal.
Q#1: does the 351 only send square, triangle and S&H when the LFO Wave is set to that or are these signals generated all the time regardless of setting.
Q#2: is the rate always dictated by the LFO Rate
Q#3 (this is likely a question for foggers or controllers forum): is the noise that is generated by 351 (from Voyager) the same as the 251 and the same as the multi-pedal will put out. If I have noise osc off on the mixer section, will it still send noise out the 351?
In short, if I can get by with noise, S+H etc. from another fogger or the pedal, is having 351 out for pressure, velocity, wheels, rather than also requiring a CP-251?
As always, too many toys to buy, too little cash. If you can answer any part of my questions or provide other feedback, I would greatly appreciate it. Thanks.
