If someone could make a tutorial on programming the 8 glide modes in a sequencer pianoroll, I would be happy!!
The frist two glide modes are the ones you may find on other synths.
#3 to 8 are rather exotic ones.
These are normally only used for experimental style, or for very special situations or playing styles.
1: normal glide
Glide is always on. Of cause depending on the set glide rate. Obvious, right?
This is the mode the Minimoog D and most other synths have.
2: legato glide
glide is only active while you play legato.
Example:
you press the first note and hold it → no glide
press a second note and hold it → glide will get active
release the second note → glide while the pitch changes to the first note still held
3: legato glide to second only
release the second note → no glide while the pitch changes to the first note still held
4: legato glide back to first only
press a second note and hold it → no glide
5: legato first note
6: mode 4+5 combined
7: legato glide back to first off
8: legato glide changing
same as mode #2, but here the glide is only active every second time you press and release a second note.
Feel free to add the missing descriptions here.
You might find it easier to grasp what the glide modes are doing by playing the Moog from a keyboard rather than programming from a piano roll. I find that each mode leads to a different playing style.
Tills desciptons in the previous post are so clear and simple you shouldn’t need a tutorial.
