I don’t why I never tried before but today I thought I would hook my two voyagers together and have some two note polyphony hapenning but I cant get it to work. It sort of worked for a while but then just hangs all the time.
I tried playing one from the other and I can get them to play the same note but I want them to play different notes. I tried playing them both from a mother keyboard but it still didn’t work.
ANybody tried it and got it to work ? I would ask Amos but I know those guys are crazy buy … thanks Roger
I guess Moog forgot to put the procedure in the manual, but the key here is MIDI note order. For it to work you must turn local off, then run MIDI out of the controlling keyboard back into it’s MIDI in, and the MIDI thru to the second voice Voyager. Then it will sort the MIDI order.
I still get a lot of MIDI hung notes. Trying to work it out? Been playing a three voice all day today!
PS: Under Midi key order:
Set both max keys to 2
Set active key to 1st on the one and 2nd on the other
If were talking about MAX Keys,
See since there are 16 Midi CHannels then you can hook up 16 Voyagers. I think that the max key will depend on the number of Voyagers that you want to activate.
My MIDI setup for this is: MIDI out from master voyager to MIDI IN on second Voyager, Midi THRU from second Voyager back to MIDI IN on first Voyager… Local Off on first Voyager. I’ve done this with a Voyager keyboard + two RMEs for 3-voice polyphony and I don’t recall getting any hung notes. Make sure you don’t have any dodgy MIDI cables in your setup, as an intermittent signal can surely cause hung notes…
Thanks Amos! I eliminated a Kurzweil Expressionmate and an Anatek MIDI thru in the loop and the hung note issue seems to be gone.
Another minor setup issue was setting the one RME MIDI note order max keys to 3. I did so with the cursor, but forgot to hit ENTER after I was done. I guess it reverted back to the previous setting without hitting ENTER? So that was also a source of some strangeness.
As I iron out the settings this is working great! Still, the first step took forever to figure out,—trun the local off.
PS: At 0:55 you can hear one of the RME voices snap to another held note. This was due to it being set at 2 voice max= hit ENTER after making the change to 3 voice max.
OK So I got it to work, I had to disconnect from my Midi interface and Logic and hook them up directly and followed Amos’ directions.
Its cool and I found if you put one Voyager on low note priority and the other on high it works better and you really have to play quite differently to make it work but it sounds very cool.
Only problme now is that I really want a Poly Voyager haha
