Configuring pedal for output volume
Does anyone have input on using a Moog EP-3 to control output volume on a Muse?
Following the minimal info from the online video and the user guides, I’ve used the quick access button for the Expression Pedal, and the video display shows the EP, but at that point, the right knob does not work, and using the pedal or adjusting the master volume via the knob does not populate selections in the video menu. I think I am missing something. I’m not seeing a volume or output selection as an option in the video display.
The pedal is fine. I’ve tried 2 EP-3 pedals - same thing, and both pedals work fine with other synths.
Also - I have tried this with the polarity switches on the pedal bottoms set to “normal,” or “other,” and have restarted with the volumes at zero (0). No difference. Any advice or help would certainly be appreciated.
Thanks very much,
Tom Cockrell
