Composing with the Theremini
To all Theremini enthusiasts like myself, I’d like to start a thread talking about tools, tips, techniques and anything else you may want to discuss regarding composing with the Theremini. So far I have not done much as I’m still getting used to playing the instrument, but with the new Theremini editor/librarian that just came out, a whole new world of sonic possibilities has just opened up to us.
So here’s my Theremini call to arms - let’s get busy writing some music for this great new instrument. And even though this is a Moog forum, I think we can also discuss non-Moog interfaces and tools that may also be applied to composition with the Theremini. Though I’m going to start with using my Moogerfoogers with the Theremini to see what kind of things I can do.
I just don’t see that there is any better place for an open and positive discussion of this topic than here.
Rich
Got the urge to write a more experimental ambient piece (haven’t written this kind of thing in years) using the Theremini and PSP Audioware’s now almost iconic N2O effect plugin. I started by creating a sawtooth-like theremin sound in the editor and then played three tracks with limited pitch content into Cubase each using the N2O plugin (using the default Lighthouse, Laryngitis and Abyss patches. Added some tube saturation and reverb. Used mostly just the wet output from N2O.
https://soundcloud.com/rk53-1/nitrous-voices-for-theremini-and-n2o
Before this I only used the Theremini pitch display to get a starting note ( playing very tonal pieces), but I notice now when playing the more experimental material that pitch display is indispensable if I map a pitch content out before I play and want to layer in pitches on top of a complex setting. I can also see now it will also come in very useful if I want to create more serial pitch content.
I have found that the pitch correction and the note display make for an effective way to play individual notes in a chord. I use an EHX Chill Switch to mute the signal while I find the note, then quickly unmute the signal for a staccator effect. You can hear it on this recording: https://soundcloud.com/rickreid/time-shadows
I also use the Chill Switch to mute the signal while I change patches. Here’s an example: https://soundcloud.com/rickreid/rosettas-tune
Count me interested. I just got my Theremini two weeks ago and I’m enthusiastic (but only stopped myself to play twice yet, but I know I’ll be spending more time exploring with it). I think we’d benefit from a common webplace to discuss & document playing with the Theremini. I’m totally new to theremins - could thereminworld.com act as the place for this? (I honestly don’t know much about that website) It’s not that I want us to divert away from the Moog forums, but I think we’d need more than a forum. For instance, I’d really like a location for sharing user-modified Theremini presets.
I’m slowly trying to build such a community-driven website, but for Animoog (see sig), I already have little spare time, so I don’t want to lead a Theremini community-driven website, but if anyone wants to begin/maintain one, I’ll be glad to contribute. Cheers – Alex
Thereminworld.com is not the place to go to discuss the Theremini. They don’t understand it’s potential, not being a “traditional theremin” - which is all they are interested in. But you can learn a lot about the theremin there.
If you are just starting here’s some tips for the Theremini if you are interested in playing melodies with it:
  1. Dial back the range to C2..C5. I’ve found this gives you are pretty good and consistent spacing between notes (linearity) for most of the range.
  2. Dial the pitch correction to about 10 O’clock. This will add some correction, but not too much so that you get over quantized - which at the beginning may actually make it harder for you as you want some fudge factor (portamento) between notes to try and make easy corrections.
  3. Make sure you set to Chromatic scale, I set root to C , but that can be whatever you like.
  4. Start with the Classic Theremini setting - and play around with it in the editor if you like.
  5. Add in some delay to your liking. The default Theremin setting does not have enough.
  6. Put on some slow music and try and play along with it. Don’t worry too much about the left hand to start. Just try and match pitches.
    This is all I did for about two weeks. But it really helped me get my ear in tune with the theremin.
And having a place to share Theremini presets is a good idea. I wonder if this site can be set up for that (if Moog is reading this?). This is the ideal place of course. But I agree a separate site devoted to Theremini would be great.
Rick,
Rosetta’s Tune is great. Is that all Theremini?
What other techniques did you use to do this? How did you get that wonderful “crackling sound”?
Rich
For sharing Theremini presets, I can easily to that, shouldn’t require much time and I actually want to try other people’s Theremini presets! If you have any, please send them to me, I’ll make them available to everyone’s benefit.
Thanks rkram53 for the tips, I just republished them on a new page: http://animoog.org/theremini/ :slight_smile:
Cheers – Alex
Thank you! I’m glad you liked it.
Every instrument sound came from the Theremini. That crackling sound is a new patch called BTWEENWORLDS. It is one of 35 new patches pre-loaded in the iPad editor / librarian app. I also used CLANGY and SPACE RADIO! from the new presets and my tweaked version of CLASSIC THRMN from the original factory patches. I think I used a couple more of the new presets toward the end, but I don’t remember which ones they were. I also used three effects pedals: the EHX Chill Switch, a Boss DD-20 delay pedal, and a Berhinger RV600 stereo reverb pedal.
Everything was performed live and recorded with a portable digital recorder connected to the output of the reverb pedal. The long delay produced by the DD-20 allowed me to play a particular patch for awhile, then have it repeat and decay as I played a new patch over the top. The older sounds are constantly fading away as the news sounds come in. It is an effective tool for simulating the Brian Eno / Robert Fripp “Frippertronics” analog tape delay effect. I have looper pedals, but I like the DD-20 better, because I don’t have to think about starting and stopping the device as I add new layers of sound.
I just used the EHX Chill Switch to mute the output of the Theremini while I dialed up new patches. With a traditional theremin you can drape your instrument cord over the volume antenna to mute the sound. This does not necessarily work with the Theremini, because you can edit the volume antenna to control more than one parameter of the patch at a time, or even to control the volume backwards from the traditional configuration.
My original recording was a bit longer than what I’ve posted. I used audio editing software on my computer to fade in and out at the points that I thought were most appropriate for a beginning and ending. I also used my computer to apply a little dynamic compression and to expand the stereo field a bit.
Thanks for sharing your process. Very interesting how you did that.
Rich
Sounds really nice, Rick!
I like that low frequency filtered crackling sound as well.
If you have any sort of midi controllers like the free Yamaha faders IPad app, you can send CC 7 to allow you to fade the Theremini in and out. CC103 just affects the Animoog oscillator, leaving any trailing delays.
That free Yamaha app can be REALLY useful.
You can assign (and completely adjust and scale) up to three different CCs to each of the 8 faders, and the X/Y pad borders can be patched to any fader combo. Turn the gravity for the center dot off, and when you launch the dot it bounces continuously around the perimeters, automating the patched faders, slow or fast, your choice.
Look at the CC list in the back of the Theremini manual…ANY of those things listed can be animated! Your carefully designed setup can be named, saved as a preset, and recalled later.
Wonderful and unexpected stuff can happen.
Hi rickreid,
Indeed, your Theremini tracks on SoundCloud are very interesting! Have you thought of toggling the setting to make them downloadable directly from SoundCloud? Is there an other way that I can get a copy of your Theremini tracks (to put on my iPod and be able to listen to them offline)? Were you planning an album or such?
Thanks! – Alex
Well, did a little improv using my new Pittsburgh Modular Foundation 3.1 synth and the Theremini. A bit of experimenting here starting with a sequenced patch on the modular. Then I actually both mixed in a Theremini patch and also ran the Theremini CV out to a Doepfer CV to MIDI converter and then fed the MIDI output of that back into the MIDI3 input card on the Foundation. The CV to MIDI card needs to be gated however so I gated that with a Foundataion clocked output. Also had a bit of clock division control and the main sequence was run by Pittsburgh Modular’s 8 note sequencer. Then I ran everything through a PSP N2O effect on the DAW for a bit more motion to the sound. Before the obvious Theremini solo comes in you can hear a bit of [pitch variation in the sequence - that’s the Theremini CV pitch output (semi-quantized) with volume antenna muted.
https://soundcloud.com/rk53-1/theremini-foundation-theremini-and-modular-synthesizer-improv
Not a masterpiece, but an interesting experiment.
Congrats on the new modular…that looks like a great musical tool in a really portable enclosure. Very interesting sounds as well. Thanks for sharing!
Have you tried patching the pitch CV directly to the oscillators? Currently with the pitch scaling turned on, the low note and high note settings scale the tracking. I found that setting them for the lowest note and around C#8 (?) got close, buy not quite in proper scale. Setting the scale to the 5ths setting makes it easier set the coarse tracking…fewer notes to deal with.
You can play with these settings to get something you like, and use one of your attenuators to fine tune the tracking. The oscillators may be several octaves apart. I built a simple ranger-scaler circuit from a dual opamp to help with this, and I’ll bet your modular can duplicate the same sort of functions. I like to sync the oscillators, and use the volume CV to push just one of the oscillators to get that “sync” sound.
Try using the MidiBridge app to patch the theremini Midi in to Theremini Midi out, and set the antenna CCs to control interesting stuff, like the delay settings or the scan position for the scannable waveforms ( currently just Animoog1 and Etherwave).
I’m glad you like my recordings, Alex. Thank you! Around the end of December or first week of January, I plan to have a new album posted to my Bandcamp page. It will definitely include “Time Shadows” and “Rosetta’s Tune.” I may record a new version of “Act now. Don’t Delay!” The album will be a “name your own price” offering, so you can either download it for free or pay me a few dollars to show your appreciation. Watch for it here in a few weeks: http://rickreidtheremin.bandcamp.com/
Thanks Rick! I’m now following your bandcamp account and I promise I’ll get your latest album with the Theremini explorations once it’s available :slight_smile:
I also plan to offer my second album on Bandcamp around the same timeframe are yours.. satri.bandcamp.com (nothing there yet)
take care & have fun! – Alex
All,
A little Holiday Cheer - Nothing like a Theremini Dingi Dongi!
https://soundcloud.com/rk53-1/theremini-dingi-dongi
Happy New Year to all!
And remember drinking and driving the Theremini is a no no!
Rich
Well I got that MIDIConnect4+ and it works great. Connected both the Behringer FCB foot controller and iPAD at the same time with no computer and things work fine. Set the Expression foot pedal to CC7 so I can control the volume with the foot pedal and use the Yamaha slider app with the left hand.
Working on my melodic playing in semi-quantized mode. No way I could play like this right now on the Etherwave.
https://soundcloud.com/rk53-1/jesu-electronique
Rich
I finally have my new album put together. You can stream it or download it at bandcamp. Payment is optional, but much appreciated My Moog Theremini is featured on tracks 1, 4 and 9. Almost everything else was created with various combinations of moogerfoogers, minifoogers and Slim Phatty, plus a few other devices. Track 11 was created with a 1965 Hammond E-111 organ.
https://rickreidtheremin.bandcamp.com/album/calculated-risk
Enjoy!
Rick Reid
Just purchased! Eager to listen to it… :slight_smile: – Alex / Satri
Thank you! I appreciate your interest and support.
