I’ve got Novation ReMOTE 37SL MIDI controller and I want to change Voyager RME banks with it. I made a Voyager template and everything
works fine except one thing:
I can scroll sounds within Voyager bank using ReMOTE’s Data/Select pot (switched on Program position) but I can’t figure it out how to change banks.
When I switch to Bank position on the same pot, Voyager’s MIDI LED indicator shows MIDI activity but banks doesn’t respond to it.
Does anyone know which CC message is changing Voyager banks so I could assign those values to one of the pots in my Voyager template?
Thanks in advance
B0, 00, 00, B0, 20, 00 = bank A
B0, 00, 00, B0, 20, 01 = bank B
B0, 00, 00, B0, 20, 02 = bank C
B0, 00, 00, B0, 20, 03 = bank D
B0, 00, 00, B0, 20, 04 = bank E
B0, 00, 00, B0, 20, 05 = bank F
B0, 00, 00, B0, 20, 06 = bank G
Hi RL, thank you for answer.
I’m afraid I don’t know how to implement listed values in ReMOTE controller (or Cubase)
In the pictures below, you can see control options that I’ve got in ReMOTE controller. I would appreciate if you could post “How to…” version for dummies
I’m pretty sure there’s more people out there having same problem with ReMOTE controller & Voyager RME. Thank you in advance!
OK, I don’t know this machine but I think it should be:
LowVal 0 HighVal 0 CC Num 0 = bank A
LowVal 1 HighVal 0 CC Num 0 = bank B
LowVal 2 HighVal 0 CC Num 0 = bank C
LowVal 3 HighVal 0 CC Num 0 = bank D
LowVal 4 HighVal 0 CC Num 0 = bank E
LowVal 5 HighVal 0 CC Num 0 = bank F
LowVal 6 HighVal 0 CC Num 0 = bank G
