Does a ‘controlmap.xml’ (CC map) file for the Voyager exist?
I’m trying to control my Voyager via ACID Pro and a CC map would save me a lot of work.
A CC listing can be found on page 76 of the current Voyager ‘Combo’ manual, available online (this manual covers both Voyager and RME versions). The list is organized by function (Oscillators, Mixer, Filter, EG, etc.), so it should provide the specific info you’re looking for.
Yeah I already have the CC list Greg, I was just being lazy by wanting an already prepared controlmap.xml file. It’s what ACID Pro uses to load CC profiles.
Hi Sub,
Guess I misunderstood the reason for your request. Unfortunately, I don’t have the software tools to create an XML file. Perhaps someone can put this together & post it on KnobTweak. Any XML code jockeys here?
Here’s an example of a control map for the Virus TI in txt form:
http://www.artistserver.com/m2/3611/1882/media/27962.txt
Here’s the actual xml file for it:
http://uploading.com/files/e79739f6/Access%2BVirus%2BTI.controlMap.xml/
I’m guessing these control maps can be used with any DAW.
