Really enjoying the new OS for my Stage Edition. Just wondering if there is a way to globally set the arp to midi clock (or LFO, which in turn could be set globally to midi), rather than having to set it up on a preset by preset basis?
Also, is there any way to force a LFO retrigger start on note on, or does this happen naturally anyway, I seem to remember a few occasions where it sounded like it was almost freerunning?
I´m hoping the new version of the editor librarian allows to set arp settings for more than one preset at the time… at this time i think it cannot be done… i hope i’m wrong…
Hi, I asked Mark at Soundtower about this, and here is his reply. It looks like you can already edit any parameter to be the same value across multiple presets, for all parameters which are supported by the current editor. This will be extended to the Arpeggiator parameters as soon as they are supported by the (updated) LP editor.
Mark écrit:
Yes, In the LP editor there is a utility called “Single Parameter
adjustment” located under the ‘Bank’ menu in the main window. Also
there is similar function in the Preset Genetics. Right now the Arp
setting are not implemented in those utilities because it is a new
feature from OS 2. It will be all added in the next update.
Yes, i’ve tried to use this feature in the program for the preset genetics and never has worked… i’ve tried before the last update though, so i don’t know if the new update has this utility fix… i’ll give it a try this weekend!!
