I’d like to put my Voyager on the top level of a 2-tier stand with my Andromeda. I’m wondering if anyone out there can recommend a stand that has a top tier that is deep enough for the Voyager and can support it’s weight.
I am using an Ultimate Support 2-tier support for man years. I am not talking about ther Aphex supports, but the ones that look like an “A” from the side.
Alternative there is also a german company calles Jaspers doing very similar supports.
I’m using one I got from Guitar Center for about $99us. It’s called a “ProLine.” It’s an X stand on the bottom with 2 bars that extend from it for the top. Very small footprint. I have a Hartmann Neuron on the bottom and my SE Voyager on the top.
Here’s the product info:
Hope this helps.
-andrew bunny
You have a Hartmann Neuron? ![]()
I use a Quik Lok QLX-2 with my Voyager on the fully-adjustable top tier. It works very well, and the adjustable height and angle allows me to position the Voyager right where I need it.
I have a 3 tiered quik loc stand with the Voyager on the top (had my JP8 on the bottom with Radias on 2nd and Voyager on the 3rd), after selling the JP8 I am using only as a 2 tier stand. These are built very well and never worried one sec. with the Voyager on either the 2nd or 3rd tier.
Thanks for the suggestions everyone. I decided to go for a ProLine and put the Voyager on the bottom tier.
The ultimate stand can be found here:
http://www.flickr.com/photos/13733030@N02/
It is massive, it is blue, it weighs a ton and it can hold a ton!
" I decided to go for a ProLine "
Several model #s are close to the same. Maybe someone knows if that bullet point is a good design. They look fine, probably stand up, but
there isn’t a bolt that goes through. There’s a narrowed pin that fits a
quarter inch into the leg. Don’t know the reasoning, just found
it mildly discomforting.
