Hi there Mothers,
I didn’t receive a calibration tool with my Mother 32 and was wondering what type of precision screwdriver/ other tool I can use in its stead.
Does anyone know an alternative that I can get?
Hopefully I won’t need it, obviously. But just in case
Well, eight years later and no answer for you, that’s sad. I have the same problem, and I don’t know where to find this tool or someting close enough to tune my Mother-32.
If anyone have an idea to help, that would be most welcome.
The “Trimmer Adjustmemt Tool” is easily sourceable, the process is a little more involved, and requires an accurate tuner, and an accurate 1V/Octive source.
The procedure requires precise steps to he followed in sequence. And Accuracy is important. Improperly conducting this process can cause further complications and lead to diagnostics and technical repair.
Additionally, this is likely sometjing that should he left to folks who confidently understand what they are doing. I’d also highly recommemd not calibrating if things are within tolerances, and only doing so sparingly, as frequent adjistments of the pot can lead to premature failure and require board level repairs.
