Has anyone tried better Powercords (oxygenefree copper cable like the Monster Powerline 300 or XLO ER 10) an recognized an improvement in Sound Quality of the voayager?
Voodoo.
Well for the most part. I mean a plastic molded cable is cheap and bad and George Lâs have less impendence for a clearer sound with guitar(because it has pick-ups). Really just try and use a decent cable thatâs not molded at the ends and keep it as short as you can.
Unless youâve got the money to spend on that $1000 cable.
Guitar pickups have high output impedances.
The Voyager and other synths has low output impedances.
The George Lâs are optimized for guitars, but you will not notice any difference with synths.
Iâm an EE and I donât see any benefit with fancy cables with synths, mixers, processors, and any other gear with active outputs. Waste of $$$.
Iâve changed the ordinary cables against Monster Prolink 1000 between mixer and voyager and noticed a BIG difference in sound quality. The monsters do not have distortion while ordinary cables have a lot of distortion. Thatâs fact as far as my ears work well. If i want distortion i use a tube amp. By the way all the famous american players use like santana, Al DiMeola, Slash use monsters.
all of them eh?
I use Planet Waves, and I love them. Iâve never had a problem with PW. Cheaper cables didnât seem to last.
I donât notice any difference in cables sound-wise. But a good cable will last a lot longer and be more dependable. And for that reason they are worth the extra money.
Havenât tried with my synths, but I bought a monster cable for my guitar earlier. Huge difference in a $120 cable and a $12 cable. I could not believe it.
Unless your using a a device with a high impedance output like a guitar, donât believe the hype. Quality cables will last longer, but synth outputs are low impedance so any loss in quality will not be noticed.
Think of it like this, if current is like water and cables are like hoses then guitars only have a small trickle flowing out of them. Any small blockage in the hose is going to seriously effect the flow. But synth outputs are like roaring streams, a little blockage wonât have any effect.
I suggest getting a mid-quality cable. Not too cheap, those will just fall apart. Besides, Moog freaks like us have much better things to blow our money onâŚlike $700 delaysâŚ
Maybe I wonât use cheap cable on my Moog Dealy
I see how an expensive power cord wouldnât do a whole lot, but I have used Monster Prolink audio cables and I can hear a difference from the ProCo cables. I can hear more nuance in the sound. Itâs pretty clear to me unless my brain is creating the illusion. Although, youâd have to have a lot of cash to burn to hook up the Voyager and all of the MFs with Moster cables which I donât.
I used to install car audio equipment and there was always a similar discussion about Monster RCA cables, Phoenix Gold, etc.
IMHO, I think thereâs definitely an advantage to using a nicer cable. I use a monter rock cable and I like it a lot. The main benefit to the monster cables is the resistence to interference. They donât seem to transmit as much external noise, especially if you donât have âcleanâ power!
