I’m new to this forum and recently purchased a LP stage 2. I use Logic 8 and I was wondering how BPMs on the LP can be adjusted. I tried the tap function on the LFO but that somehow doesn’t work out too well. Is there any way to set the LP up so that it adapts to whatever BPM count Logic is set at, maybe through some USB function? I read that there was a way to adapt BPMs with the Midi Clock function but i don’t really understand what that means and how it works. Any advice is much appreciated!!
…and you’ll also need to make sure that Logic is set to output MIDI Clock… poke around under options or preferences ( I don’t have Logic) and you’ll find it, if it is not already checked by default. I just sucessfully got my LP to do this with Sonar, but it took just a little bit of tweaking in the program.
