Bank Select in Messenger
I’m stoked for this keyboard, but stumped trying to send bank select commands from my MPC Live (III). You can send Program Change that works, but the Bank Select MSB/LSB commands are ignored. Right now, it just stays on bank 9, no changes other than the programs. if I select Prg 19, then I’m up to patch 3 in bank 10, but the bank selection on the panel doesn’t change.
I select LSB 6, MSB 11, then my midimonitor shows:
CH 1 CC 0 11
CH 1 cc 32 6
ch 1 prgmchg 19
I have tools to transform midi messages (I use a midihub in the rig) but. kind of stumped on how to get what I want
same issue here, messenger not responding to bank select from Cubase midi track or my midi controller, it responds to program change but not banks, I guess we have to submit a ticket,
also I see a support chat but not a ticket system,
I have a ticket in, they say it is a bug and has been given to the the software team to fix.
Moog Messenger – MIDI Bank Select solution for all 256 presets (Cakewalk SONAR .INS file)
After experimenting with MIDI-OX (assisted ny ChatGPT), I found how to access all 256 presets of the Moog Messenger using MIDI Bank Select and Program Change.
The Messenger organizes its presets into two groups:
  • CC32 (Bank Select LSB) = 0: Banks 1–8
  • CC32 (Bank Select LSB) = 1: Banks 9–16
Within each group, Program Change values 0–127 select the individual presets.
For example, to select Bank 16 / Patch 3 on MIDI channel 1, send:
  • B0 20 01 — Bank Select LSB = 1
  • C0 72 — Program Change 114
An important detail is that the Messenger retains the last Bank Select LSB value received. Therefore, Program Change messages alone may select sounds from an unexpected bank, depending on previous MIDI commands.
I also prepared a Cakewalk SONAR instrument definition (.INS) with 256 generic preset names (Moog 1 through Moog 256), using Controller 32 for bank selection.
I’m sharing the file for anyone using SONAR or another Cakewalk-compatible DAW.
Tested with Moog Messenger firmware 1.1.0.
Copy the text into a plain text file and save it as Moog_Messenger_256.ins. Then import it into Cakewalk SONAR using Options → Instruments → Define → Import
; Moog Messenger - 256 presets - Cakewalk SONAR 4
; Tested: CC32 LSB 0 → physical banks 1-8; LSB 1 → banks 9-16
; Each group uses Program Change 0-127 (16 programs per physical bank).
; SONAR Bank Select Method = Controller 32 only (BankSelMethod=2).
; SONAR Bank 0 = Moog banks 1-8; SONAR Bank 1 = Moog banks 9-16.
; Generic names can be edited as user presets are saved.
.Patch Names
[Messenger LSB 0 - Banks 01-08]
0=Moog 1
1=Moog 2
2=Moog 3
3=Moog 4
4=Moog 5
5=Moog 6
6=Moog 7
7=Moog 8
8=Moog 9
9=Moog 10
10=Moog 11
11=Moog 12
12=Moog 13
13=Moog 14
14=Moog 15
15=Moog 16
16=Moog 17
17=Moog 18
18=Moog 19
19=Moog 20
20=Moog 21
21=Moog 22
22=Moog 23
23=Moog 24
24=Moog 25
25=Moog 26
26=Moog 27
27=Moog 28
28=Moog 29
29=Moog 30
30=Moog 31
31=Moog 32
32=Moog 33
33=Moog 34
34=Moog 35
35=Moog 36
36=Moog 37
37=Moog 38
38=Moog 39
39=Moog 40
40=Moog 41
41=Moog 42
42=Moog 43
43=Moog 44
44=Moog 45
45=Moog 46
46=Moog 47
47=Moog 48
48=Moog 49
49=Moog 50
50=Moog 51
51=Moog 52
52=Moog 53
53=Moog 54
54=Moog 55
55=Moog 56
56=Moog 57
57=Moog 58
58=Moog 59
59=Moog 60
60=Moog 61
61=Moog 62
62=Moog 63
63=Moog 64
64=Moog 65
65=Moog 66
66=Moog 67
67=Moog 68
68=Moog 69
69=Moog 70
70=Moog 71
71=Moog 72
72=Moog 73
73=Moog 74
74=Moog 75
75=Moog 76
76=Moog 77
77=Moog 78
78=Moog 79
79=Moog 80
80=Moog 81
81=Moog 82
82=Moog 83
83=Moog 84
84=Moog 85
85=Moog 86
86=Moog 87
87=Moog 88
88=Moog 89
89=Moog 90
90=Moog 91
91=Moog 92
92=Moog 93
93=Moog 94
94=Moog 95
95=Moog 96
96=Moog 97
97=Moog 98
98=Moog 99
99=Moog 100
100=Moog 101
101=Moog 102
102=Moog 103
103=Moog 104
104=Moog 105
105=Moog 106
106=Moog 107
107=Moog 108
108=Moog 109
109=Moog 110
110=Moog 111
111=Moog 112
112=Moog 113
113=Moog 114
114=Moog 115
115=Moog 116
116=Moog 117
117=Moog 118
118=Moog 119
119=Moog 120
120=Moog 121
121=Moog 122
122=Moog 123
123=Moog 124
124=Moog 125
125=Moog 126
126=Moog 127
127=Moog 128
[Messenger LSB 1 - Banks 09-16]
0=Moog 129
1=Moog 130
2=Moog 131
3=Moog 132
4=Moog 133
5=Moog 134
6=Moog 135
7=Moog 136
8=Moog 137
9=Moog 138
10=Moog 139
11=Moog 140
12=Moog 141
13=Moog 142
14=Moog 143
15=Moog 144
16=Moog 145
17=Moog 146
18=Moog 147
19=Moog 148
20=Moog 149
21=Moog 150
22=Moog 151
23=Moog 152
24=Moog 153
25=Moog 154
26=Moog 155
27=Moog 156
28=Moog 157
29=Moog 158
30=Moog 159
31=Moog 160
32=Moog 161
33=Moog 162
34=Moog 163
35=Moog 164
36=Moog 165
37=Moog 166
38=Moog 167
39=Moog 168
40=Moog 169
41=Moog 170
42=Moog 171
43=Moog 172
44=Moog 173
45=Moog 174
46=Moog 175
47=Moog 176
48=Moog 177
49=Moog 178
50=Moog 179
51=Moog 180
52=Moog 181
53=Moog 182
54=Moog 183
55=Moog 184
56=Moog 185
57=Moog 186
58=Moog 187
59=Moog 188
60=Moog 189
61=Moog 190
62=Moog 191
63=Moog 192
64=Moog 193
65=Moog 194
66=Moog 195
67=Moog 196
68=Moog 197
69=Moog 198
70=Moog 199
71=Moog 200
72=Moog 201
73=Moog 202
74=Moog 203
75=Moog 204
76=Moog 205
77=Moog 206
78=Moog 207
79=Moog 208
80=Moog 209
81=Moog 210
82=Moog 211
83=Moog 212
84=Moog 213
85=Moog 214
86=Moog 215
87=Moog 216
88=Moog 217
89=Moog 218
90=Moog 219
91=Moog 220
92=Moog 221
93=Moog 222
94=Moog 223
95=Moog 224
96=Moog 225
97=Moog 226
98=Moog 227
99=Moog 228
100=Moog 229
101=Moog 230
102=Moog 231
103=Moog 232
104=Moog 233
105=Moog 234
106=Moog 235
107=Moog 236
108=Moog 237
109=Moog 238
110=Moog 239
111=Moog 240
112=Moog 241
113=Moog 242
114=Moog 243
115=Moog 244
116=Moog 245
117=Moog 246
118=Moog 247
119=Moog 248
120=Moog 249
121=Moog 250
122=Moog 251
123=Moog 252
124=Moog 253
125=Moog 254
126=Moog 255
127=Moog 256
.Instrument Definitions
[Moog Messenger - 256 Presets (LSB)]
BankSelMethod=2
Patch[0]=Messenger LSB 0 - Banks 01-08
Patch[1]=Messenger LSB 1 - Banks 09-16
Observation: bank and patch will be selecter by MIDI messages, but corresponding button will not light up.
