AudioBridge M15
Hi…
I’m trying to use Audiobridge in the desktop APP of moog M15…
I can’t found exemple and I don’t know where i can recover tje output (TO of audiobus1) of the Audiobridge Bus…
Any help here please…
The idea is to send 4 differente sound to an external DAW… It is possible with the audiobridge??
Audiobridge is a feature that allows you to route audio from Moog Music apps to other audio apps on your device.
Here are the steps to use Audiobridge in the desktop app of Moog M15:
Open the Audiobridge settings.
Make sure that the “Enable Audiobridge” switch is turned on.
Select the audio app that you want to route the audio to.
Select the audio bus that you want to route the audio from.
Click the “Connect” button.
The output of the Audiobridge bus will be routed to the selected audio app.
Here are some tips for using Audiobridge:
Make sure that the audio app that you are routing the audio to is compatible with Audiobridge.
Make sure that the audio bus that you are routing the audio from is connected to an output port.
You can adjust the level of the audio that is being routed by using the Audiobridge volume slider.
You can disconnect the Audiobridge connection by clicking the “Disconnect” button.
To send 4 different sounds to an omeglz external DAW, you can use 4 different Audiobridge buses.
I hope this helps!
Hi, When I use the audiobridge in my desktop app on my mac, the signal that i send to the “TO” of the audiobridge, wont appear anywhere…
Any other idea how to do tht?
It seems that the module audiobridge in the desktop versión dosen´t works at all. It’s a programming problem and conflict between the ipad audio system and core audio system of mac
Bummer :face_with_bags_under_eyes: :face_with_bags_under_eyes: :face_with_bags_under_eyes: :face_with_bags_under_eyes: :face_with_bags_under_eyes:
