Audio output as CV
Hi friends!
You should check this tutorial video.
‘Using Ableton to provide control voltage for a Moog Slim Phatty’
http://www.youtube.com/watch?v=qJ4wyz7a27g
That guy uses his audio card’s output as CV and it works.
All you need is to route some audio signal to your moog’s cv input, no need only Ableton, every other DAW software should work.
The computer audio output’s voltage seems to be almost the same. (But try it at your own risk!).
I did some check today with my audio interface and Little Phatty and it works too, even with unbalanced cable.
Even though this type of CV is not ‘clean’, but there are many interesting possibilites, for example to use drumloop or noize loop as source for filter cv.
The idea is the same as MOTU Volta plugin uses.
check out Expert Sleepers Silent Way VST CV processors
cheers :wink:
DL
I recommend using only unbalanced cables for this patch to avoid anything that may happen from connecting the 5V supply from the LP’s jack to the balanced audio out.
Useful note about cables from here: http://www.expert-sleepers.co.uk/siwacompatibility.html
A Note On Cables
In general special cables are recommended when using a DC-coupled audio interface as a source of CVs. Most audio interfaces have balanced outputs (on TRS ('stereo') jacks or XLRs), while synth CV inputs are unbalanced (usually on TS ('mono') jacks or minijacks). If you use a regular stereo or mono jack lead, you'll be shorting out one of the balanced output signals (usually the R (ring) to the S (shield)). While this probably wouldn't be a problem for normal audio use, when outputting the sustained voltages that are useful as CVs you risk damaging the interface hardware.
The usual recommendation is to make up special cables with a TRS jack at one end and a TS at the other, connecting T->T (tip to tip) and S->S (shield to shield) while leaving the R (ring) floating i.e. unconnected.
An alternative is to wire a TRS jack to two TS jacks, connecting one T->T/S->S and the other R->T/S->S. This then gives you two copies of the output CV, one of them inverted, which is particularly useful from LFOs. Note that this cable configuration is identical to that of a regular "Y" audio insert lead.
I’m gonna try it this weekend, since I have Y-insert cables
Thanks for the info on the balanced cables for cv, the insert cables sound like they could be a lot of fun.
I’ve checked the Y-cable, it works great :slight_smile:
so, simple sine wave soft synth with volume automation or separate notes with differenet volume (=velocity) can act as cv source.
also i’ve tried drumloops
the first bar was recorded without any cv applied and then you may hear different variations of cv, applied as described above
http://dl.dropbox.com/u/12118770/cv_test.mp3
Oh yeah, of course this all stuff are for experimenting or getting unusual things from phatty.
I prefer using midi controlled filter (thanx god phatty has midi) or velocity-to-filter feature.
but…
