Arpeggiator rate LED brightness not dimmable by Editor
I got my brand new Subsequent 37 yesterday and found the arpeggiator rate LED extremly bright and disturbing.
The LED brightness slider in the Sub 37 CV Editor dims everything on the panel perfectly but the arpeggiator remains at full level.
I am wondering if this a known behaviour or only a problem on my device? Maybe a few of you could crosscheck if this is a “normal” behaviour or if I better should return my device?
In the meantime the Moog support confirmed the behaviour as a firmware bug. So with firmware v1.2.0 this is a “normal” behaviour even though not intended.
I’m new to this forum and maybe it was discussed earlier but… any rumors if after all these years there will be 1.3.0 with fixes/updates?
