Arpeggiator lagging when MIDI sync'd
I’ve got my Muse hooked up to my MIDI interface, and the arp seems to lag quite a bit. So it’s tempo sync’d with my DAW, but there’s latency essentially. So it’s barely usable if I’m trying to play the arp along with whatever’s going on in my DAW. Anyone have this issue? Or could I be doing something wrong?
In the pinned thread it is mentioned that Moog are aware of both clock and general latency issues; hopefully their next firmware will tighten things up. Latency, Dropped Notes, and Clocking (Update from Moog Music) - Moog Muse - Moog Forum
1.30 firmware and I’m still having this problem. It’s super annoying.
This is still an issue with 1.4 firmware. Oddly enough, my BS2 that is connected with MIDI THRU from the Muse is perfectly in sync, but the Muse is not
Try reducing your DAW’s buffer size first. If that doesn’t help, check if the Muse has a specific “MIDI Clock Sync” latency adjustment in its settings or your DAW’s MIDI preferences.
