Anyone recommend protective hard/soft cases for Minimoog D?
I just wanted to know if anyone could help recommend any sites that either stock or make (if not too expensive) hard protective cases to fit the dimensions of an original minimoog. I’m not looking for anything too heavy e.g. military/flight cases.
I’m also looking out for softcases too, which makes things a little more convenient.
There seems to be loads out there for desks and guitars - but near zilch for keyboards.
(I am based in the UK.)
Ben
Try http://proaudiostash.co.uk/products/cases/keyboard-case/49.shtml
They may have something, and if not, they may help you find it. Good Luck! :mrgreen:
The model D minimoog will fit in the Voyager soft shell case that Moog sells.
But the Voyager is a bit different in dimensions. So be prepared to add some additional foam here and there or cut a bit off.
The ATA case for the Voyager is protecting very well. But also very bulky.
I got a classic plywood case for my minimoog. And it is very good to transport the Mini in a car.
I own a Voyager and a model D, as well as the soft shell bag. Yes they are dlightly different dimensions, but the model D does fit the bag as it flexes around the case.
