I followed the instructions to a tee and after the first attempt, found my 37 stuck with the “blank screen and LEDs on” mentioned in the instructions. So, I tried to start at “Panel firmware update” and go from there. I noticed that when sending this (the erase) SysEx via c6, it’s incredibly brief. I verified that the Sub37 was selected in Config dialog. Also, the MIDI LED only ‘blips’ once when I send it – no constant blinking. If I try to send the panel SysEx the same behavior occurs, the only exception being that it takes about a minute via c6 and I can watch the progress bar indicate transmission (again making sure the 37 is selected in the configuration of c6).
The 37 doesn’t reboot or anything - just stays at a blank screen, LEDs on, and arp light going at about 1Hz. I tried restarting my Mac and beginning at the first step, but no joy…
Any ideas? The instructions don’t mention it, but are you supposed to redial the Fine Tune and Cutoff CCW and hold pitch up and cycle power on the 37 before the panel erase and panel loading steps?
If it helps with the diagnosis, when I send the panel Sysex, the MIDI stays red (no blinking) and the arp light is off, and when it finishes, MIDI blinks red and arp blinks, too…
(I’m really not trying to be hypercritical here, but the whole firmware update process is sketchy, IMHO. I could understand sticking with SysEx for legacy reasons. But, given that it can’t even be sent over DIN, why not make it more drag-and-drop via USB?)
