Animoog Z Sythesizer on Maschine 2 SW 4k "scaled" resolution iMac 21"
Animoog Z Synthesizer plugin on Maschine 2 SW has an issue with my iMac 4k having scaled resolution.
The plugin opens and displays as it should in standalone and on Serato Studio.
A similar problem was solved with Reason Rack plugin on Maschine 2 SW on my iMac, the fix for that was to open it in another daw and adjust the zoom on the rack. However this time it does not seem to be an option with MoogMusic Animoog Z Synthesizer plugin.
One solution is to lower the scaled res of the iMacs display, this solves the issue with displaying the plugin, though it is not ideal, as I use the scaled resolution to the max.
Peace
