I’d love to be able to set filter cutoff keyboard tracking beyond 100%. A multiplier in the menu to set the range of the KB tracking 100%, 200%, or 400% would be great!
Hey Amos - really looking forward to the next Slim update - you guys are awesome. I think you already know about this one, but there is a bug in saving LFO clock divisions to presets - they always end up back at their defaults. Also, as someone else has mentioned, assignable MIDI CC numbers would be out-of-this-world amazing - some controllers are more limited than others in their MIDI flexibility and this would open HUGE doors for me on this instrument. Sincere thanks for all that you do.
The Phatty’s seem to be missing this option.
LFO SYNC MODE:Internal Master
LFO SYNC MODE:Internal Independent
ARPEGG MODE:Internal Master
ARPEGG MODE:Internal Independent
In Master mode the LFO and Apeggiator would would be synced to one internal clock, adjusted by the rate knob or tap tempo. LFO and ARPEGG should maintain independent clock divisions.
Internal Independent would be the current operation.
Thanks for the consideration
The phatty clock handling definitely needs work. I hope in general, Amos focuses on improving the current feature implementation over adding new bells and whistles.
Loopable env, osc trig sync, ect. are all great features to add. But if it comes down to limited time to work on the code, I’d like to see the user experience of the current features smoothed out a bit. #1) clean up the few remaining bugs
After that menus, CC tables, and clock implementation need some work.
Do you mean the REPEAT style “AMPLIFIER ENVELOPE REPEAT” currently found on the SubPhatty?
There’s a similar “REPEAT” function on the Envelope Generator on the Telemetry/Vostoks from Analogue Solutions, which you can access directly by pulling out a hardware knob though it’s not patched or normalled into the VCA so you can send it to any destination — i think it’s modelled after EMS synth/Putney
hello, here are my suggestions for sub phatty options: 1. I’d like the option to bypass mod.wheel so that PWM, pitch or filter can be modulated independent of the wheel position. 2. mod.wheel controls filter cutoff instead of filter mod.depth. 3. pitch bend on/off for osc 1 & 2. 4. hold note when MIDI CC sustain is sent to Sub phatty. 5. Option to switch modulation source to filter env. individually for filter, PWM & pitch.
/jocks13 in Sweden
