After Midi Learn only one similar output signal
Hey there,
i got my minitaur today and was really happy, everything worked nice in combination with my roland pk5 base pedal. Then I connected the Taur via usb to my laptop and updated the firmware. when I put it back on the amplifier and the pk5 there wasn’t any output signal anymore. so i tried the “hit the 4 buttons”-midi-learn thing with the pk5 and the result was, that all what was coming out was on similar tone. i turned every knob and hit every single pedal on the pk5… the same tone over and over.
I really don’t know what went wrong so if you PLEASE could help me. It would be so great.
Thanks a lot!!!
Which firmware did you install, and do you still have the firmware file that worked before?
i applied the 2.0.0 and the one wich was applied before was the one it came with. now… next problem popped up this morning… my laptop doesn’t recognize the unit anymore…
which version of the USB Moog Midi driver are you using?
is the sound a very low grumble? Do the note calibration routine. similar thing happened to me recently
I’m not sure what you’re supposed to do with the calibration routine thing, but I used it recently.
I just let it go for a long time and then turned every knob. It seemed to be doing a lot of sweeps - filter and oscillator and whatnot.
No real directions I could find for it pertaining to how long it should take to complete.
