So, this is more than a year later and not a soul has responded to this.
And the reason I have found this thread is because I have exactly the same problem. Midi via USB seems to be off. There does not seem to be a setting for this, so would the (horrifying) conclusion be that there is no MIDI via USB?
UPDATE: I got it to work. It turns out that my Muse does not agree with a certain port in my USB hub, but likes another one. (It is the top-of-the-line CalDigit hub.)
Muse is the first midi device that I have had connected, that has had this kind of delicate sensitivity to what specific usb port, but ok, now it works.
UPDATE 2: For some reason the timing on midi via usb is horrible. Constantly varying between bad and half a second bad. My Matriach performs flawlessly on the same connection, so…
For future reference: The Muse seems to be more picky about USB cables than I am used to. I finally got it to work using a cable with ferrite cores at both ends. (Unclear if it about the ferrite cores or not, but it would be worth a try, if you are having problems.)
